跳转到主内容
Hybrid notebook/tablet released in December 2015. Manufactured by Acer, the Chromebook R11 is an inexpensive option among an already-cheap line of notebooks.
18 个问题 查看全部
How do I repair my touch screen?
I dropped my acer r11 chromebook and now my touch screen does not work.
How do I repair it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
5条评论
a couple of days a go my laptop screen stoped working help
完成的
Yesterday I logged on to my Acer R11 to do something and the touchscreen wouldn't function properly it still registered but it wouldn't work right, it was dropped 5 days ago but still worked fine afterward so I don't think that had anything to do with it, and it is not even 2 weeks old, I hope I don't have to replace it.
完成的
I dropped mine during class and grabbed it right away. I found that I could not use the touchscreen but I could still use the stylus and the keyboard. And now while seeing how to fix it I somehow disabled the touchpad. This is the Chromebook pro by samsung.
完成的
how did you fix it?
完成的
my acer chromebook r 11 fall touch screen not work
完成的
添加一条评论
8个答案
最有帮助的答案
You can try disassembling the laptop and check if the connection between the motherboard and touchpad is loose. It is possible that the connection got loose because of the bump/hit. Else, the touchpad maybe damaged, and in this case, you need to contact a repair technician.
这个答案有帮助吗?
得分 3
1条评论:
Where is the motherboard once you dissassemble it?
完成的
添加一条评论
this is a replacement Digitizer.
https://www.laptopscreen.com/English/mod...
This is unfortunately a video of the Acer Aspire R11, hinge replacement, so some screws may be different, but the concept is the same. so the skillsets are transferrable.
https://www.youtube.com/watch?v=nzAmaOuc...
Be sure to keep the adhesive as warm as you can to allow for easier removal.
这个答案有帮助吗?
得分 2
添加一条评论
At previous days my laptop touch is not working
这个答案有帮助吗?
得分 2
添加一条评论
maby go to a laptop fixer place or reset the laptop
这个答案有帮助吗?
得分 1
添加一条评论
It is likely a hardware fault.
Check if the connection between the motherboard and touchpad is loose.
这个答案有帮助吗?
得分 1
添加一条评论
If there is no break or burning in the screen, you can relax in the screen clips. You should open the device and put the dog in its proper place. If you can not do this, you should go to the mobile maintenance mechanic
这个答案有帮助吗?
得分 1
添加一条评论
this is a hardware breakdown issue. I would say to bring it in to an expert.
这个答案有帮助吗?
得分 1
添加一条评论
If your a personal user and not a student I would look for the repair guide or take apart the device and get the serial number or part number of the device. Look it up and order the part. When repairing make sure the battery is unplugged this is extremely important. If your not comfortable I would take the device to a repair technician. Screens are really the easiest thing to fix.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dennis Bolestridge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 4,296
