跳转到主内容
The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
112 个问题 查看全部
Can't turn on my Phone
Hi
when I'm charging my phone I can see that my LCD is working properly
but when I'm pressing the "turn on" button nothing is happening
The phone is fully charged, what can cause this issue? Maybe motherborad or other part?
I would like to mention that I disassemble the phone, maybe I touched something
Thank you !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Does the power button move like it used to? Perhaps it isn't lined up quite right.
If you can, you could try to lift the screen / board out again and try to activate the power switch directly on the board with your finger instead of using the cases power button to see if maybe the case button is stuck or not making contact.
The iFixit breakdown is here: Huawei P8 Lite Teardown
这个答案有帮助吗?
得分 0
1条评论:
yes, I'v tried that . that was my assumption as well
but the case button is not stuck and it seems connected
any other ideas ?
完成的
添加一条评论
any other ideas ?
这个答案有帮助吗?
得分 0
添加一条评论
anyone slese ??? phone not working
thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
or avivi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 210
