跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
Bad charging and Error 4013
Hello :-)
I have an very weird issue on a customers iPad Air 2 Wifi Version.
First of all its not booting, not even the Apple Logo appears.
Second thing is that when I plug it in for charging on my MacBook, nothing happens as well, the screen remains black.
When I plug it in to the 12W iPad Charger, after some minutes on charging, it tries to boot, but the iTunes symbol appears and tells me to restore the device.
When I try so, Error 4013 appears.
Of course I've tried it in DFU Mode ;)
Some research on this lead to a defective NAND chip, but im curious if not maybe the battery could be the issue..
Before I send the device to a technician who's able to swap the NAND chip, I would like to know if somebody here had the same issue and probably a solution that does not require any kind of microsoldering.
Would be happy for any kind of tip.
Thanks and have a wonderful day people :-)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
honestly i would try changing the battery before anything it sounds like it is not getting enough juice . i would also contact apple and see if they can run a diagnostics on it.
iPad Air 2 Battery图片
产品
iPad Air 2 Battery
$54.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jimmy industries 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 618
