My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Tweezers? Here is a video of someone getting one out:
这个答案有帮助吗?
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
这个答案有帮助吗?
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 173
总计 21,834
2条评论
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
由 Beth ann Poole 完成的
Grateful it worked
由 Nintai Neville Nfor JR 完成的
