跳转到主内容
Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
89 个问题 查看全部
My 1980 Mx 175 G loses spark when in gets hot?
My 1980 MX 175 G runs really good until it warms up after a while and it starts to lose its spark you can here it then it will lose it all the way then when it cools down it regains its spark and I can start it again what do you think it is I tried 2 different ignition coils that didn't work do you think it's the CDI box?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Probably The CDI Wires Melted when it gets hot then loses spark. if it cools down the contacts reattached
and creates spark
hope it worked
这个答案有帮助吗?
得分 1
6条评论:
It’s gotta be in the cdi itself then cause all the wires are gone over and bad spots were fixed
完成的
could you try the CDI in another motorcycle?
完成的
if The CDI fails to spark in another motorcycle then its gonna be the CDI
完成的
so if that happens then replace the CDI
完成的
Ok guys I got some parts coming I can try thanks
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Tristan Bullard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 89
