跳转到主内容
A laptop in Sony's FE series produced for the UK and other non-US markets.
1 个问题 查看全部
Up to what cpu can I upgrade? (VAIO VGN-FE31b/w)
Hi.
I am using very old SONY VAIO VGN-FE31B/W, which I bought in Japan over 10 years ago. And I installed Bodhi linux. It goes so well till now.
Anyway, I don't like the cpu of it; Intel Celeron(R) M 430 1.7Ghz.
I upgraded most parts of this laptop, and lastly, I hope to be able to upgrade the cpu.
Is there Anybody who could tell me up to what kind of cpu I can upgrade it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sadly the CPU is soldered to the logic board which is common in laptops. You would need to replace the full logic board to the best that Sony offered in this series which is likely more expensive than just buying a new system.
这个答案有帮助吗?
得分 2
评论:
Not exactly. The CPU in sony vgn fe31b/w is not soldered at all.
完成的
添加一条评论
Hi @hbmg as usual, if you have any important data, please backup first.
What I will suggest you to do is to try updating your laptop to the latest bios possible.
to really support, it really depends on the bios, what i do is normally i will compare the specs of what it can the laptop mainboard can support the processor, e.g.
listed on the website of the configuration,
https://www.cnet.com/products/sony-vaio-...
http://www.computer-specifications.com/s...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 5
总计 336
