跳转到主内容
16.0 MP Digital Camera with a 30x long range zoom and 3.0-Inch LCD.
12 个问题 查看全部
How to recover lost photos after processing in Adobe Illustrator?
I have to deal with the processing of photos all the time. I use Illustrator to edit and load. I never had reason to doubt this program until today's unusual problem. Instead of a large photo, the computer opens an error message that the file is corrupt and can not be opened. How can I return it? I do not have time to fix everything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Then you can't open .ai file via any method apply more powerful solutions as ai file repair software
This one blog is very interesting, it is related your issue - http://smallbusiness.chron.com/recover-w...
It is the source of guide below: https://helpx.adobe.com/illustrator/kb/t...
Place the damaged Illustrator file in a new Illustrator file.
Important: This solution doesn't work if you didn't select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
1. In Illustrator, choose File > New.
2. Select the appropriate size and color mode, and then click OK.
3. Choose File > Place.
4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
5. Name and save the file.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
XtoumoAvila 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 69
