跳转到主内容
This versatile wireless broadband router released by Verizon in 2006 supports Ethernet and Wi-Fi networks.
Firmware update broke my router?
I tried updating the firmware and the firmware. After it was done, the power light and WAN light will light up, but after the power light turns green it blinks for a few seconds before the router restarts. Is there a way to fix this, or is it completely broken?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Nova Wolf was there a problem with the router before you updated the firmware? if so what was the issue . If not why did you update it. Did you reset the router after doing the firmware update? This troubleshooting wiki may help
Verizon M1424WR Troubleshooting
It kinda sounds like a factory reset is in order. Use the reset button on the back of the router and in doing so you will need to reset passwords and user names
Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
I’m not familiar with this router but if there is a way to reset it try that. There usually is a way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nova Wolf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 229
