跳转到主内容
Repair information for media player accessories.
How to open the case of Creative D100 bluetooth speaker?
Dear all, have anyone an idea how to open the case of this speaker? Under rubber pads below it - there are no screws. I only see something below front material - something like 8 metal washers with small hole inside - I was trying to pull them out with crochet hook but with no luck. Material also looks non removable.
The aim of this is to look for the possibility to attach external antenna as one built-in is weak.
Big thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
I have found some info at FCC: https://fjallfoss.fcc.gov/eas/GetApplica...
Now analyzing it...
完成的
This link is more appropriate: https://fjallfoss.fcc.gov/oetcf/eas/repo...
完成的
It looks like those washers were to be used with screws BUT instead I feel adhesive foam little below them - nightmare - it looks like the whole front is glued :(
完成的
I've been trying to figure this out, I got a quarter stuck inside and it's screwing it up.
完成的
添加一条评论
2个答案
最有帮助的答案
I was able to pry the cover off by inserting a thin blade around the top middle and working around the perimeter.
There are 8 Phillips screws in the recessed holes. After removing them, the front plate comes off easily.
There was a bunch of hot glue on the underside of the speaker grill directly under the "creative" name but it came off fairly easily.
这个答案有帮助吗?
得分 3
添加一条评论
Looking at those pics, It seems your right about the glue, looks like one tough cookie. However If you absolutely must open it, a heat gun and a metal spudger should do the trick. Use the heat gun to melt the glue and make it less adhesive, then, use the spudger to pry open the case.
Best of luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Krzysztof 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 10,724
