跳转到主内容
中兴手机维修指南
Why can't I use the SD Card as Internal Storage?
Question kinda says it all, but here goes; just recently got a 64-gig SD card to keep my apps on in my phone , which is a Z837VL, and am unable to see the instructions that would let me set it as internal storage. Google results just keep telling me to pick the option that isn't there in the first place. Phone is up-to-date, otherwise.
Any thoughts? Is this just really, really obvious, and I'm being an idiot?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
You can’t use an sd card to store all your apps. If you go into settings then apps, click on an app and if in the next page it says ‘transfer to sd card’ then you can move it. Not all apps can be moved.
这个答案有帮助吗?
得分 1
添加一条评论
Put the SD card on your Android phone and wait for it to get detected.
Now, open Settings.
Scroll down and go to the Storage section.
Tap the name of your SD card.
Tap the three vertical dots on the top right corner of the screen.
Tap Storage Settings.
Choose format as internal option.
On next screen, you have the final chance to decide whether you want to change your mind. Tap Erase & Format if you want to format your SD card as internal storage.
You will be notified if Android finds that your SD card is slow. Tap OK to continue.
You can start the data migration process now or do it a later stage.
Tap Done to finish storage adoption process for your SD card.
After the format process completes, you have the freedom to use your removable SD card as a ‘somewhat’ permanent storage. But keep in mind, it’s not hot swappable like the portable SD cards. So, don’t remove it without using the Eject option. Moreover, you can practically remove the adopted storage but it is not recommended as it may cause errors on the device.
这个答案有帮助吗?
得分 0
添加一条评论
I still can't access the SD card details using these options
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Grayson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 1,562
