跳转到主内容
Personal computer produced by Toshiba in early 2014 . The Satellite S55T-B5335 has a 15.6" touchscreen display, Intel Core i5 processor, and 1 TB hard drive.
12 个问题 查看全部
Do I need a new digitizer or LCD?
I have a laptop with a cracked screen, and the touch screen works until a certain point of the screen (the marked red area of the picture). Does this mean I need to get a new digitizer? or is this just an issue with the LCD.
I also have a horizontal green line that goes across my screen, is this the LCD?
Thanks in advance!
(also my laptop is a satellite s55t-b5233, but I wasn't able to pick that model from the device list)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Well, i'm guessing the lcd and digitizer are sepperate since its a touchscreen laptop, so i'm guessing you are fine with just replacing the ' touchscreen part'.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the replies! I will try switching out the digitizer and hopefully that will fix it. :)
完成的
Good luck replacing it !
完成的
添加一条评论
The image itself does not present any significant damage if any at all, so you should be fine just replacing the digitizer.
From the (veryveryvery quick) research I've done, the LCD and Digitizer are separate and not glued together as in some models, so the digitizer alone can be replaced, it seems.
There are quite a few tutorials on YouTube and Google on how to replace it.
Let us know of any other questions or issues that might come up.
这个答案有帮助吗?
得分 1
2条评论:
That's helpful to know. Google has been and will continue to be my friend.
完成的
Best of luck, Billy, let us know how it turns out and if there's anything else I can help you with!
完成的
添加一条评论
添加你的答案
billyboy062002 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 223
