跳转到主内容
加入维修社区 - 创建账户
标准款Xbox 360的轻薄升级款,配有250GB硬盘和Wi-Fi功能。维修需要用到复杂且特殊的工具。
Xbox won't power, orange light (maybe red?) on power brick
I bought a new brick and new cable, checked the usb ports, changed outlets, and still won't turn on. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Can you please try https://support.xbox.com/en-US/xbox-360/... and https://support.xbox.com/en-US/xbox-one/...
Seems like a cooling or stable power to the PSU issue.
Report back after you've tried those methods.
这个答案有帮助吗?
得分 1
4条评论:
Nope, didn't work.
完成的
Is the blinking light always on or does it blink?
I don't know much about that issue, but most of the information I find seems to be related to cooling on either the brick, PSU, or ventilation of the XBox itself.
Do you have any friends with another xbox and power brick you can mix and match, to see if the issue is still present?
Your XBox on his power brick, and your power brick on his XBox?
Interesting issue, please report back with any developments.
完成的
I bought a new one and still the light shows, also I can't even open the xbox to change out, might try to open it again.
完成的
Then it's definitely a problem on the XBox side and not the brick.
Ventilation or heating, or even a PSU issue...
I'd try opening it up if you're not afraid of losing the warranty, and see how it fares. Built up dust, corrosion or out of place parts are issues to look out for.
Let me know if you do crack it open!
完成的
添加一条评论
As with the above post I would also check if it is connected to a power strip if the strip is functioning properly. Those do go out from time to time. Try an outlet you know that works.
这个答案有帮助吗?
得分 0
添加一条评论
If you need someone to open and clean it up lmk. And you can send it this way through ups
这个答案有帮助吗?
得分 0
添加一条评论
Was it flashing? If it is, get a replacement for it... That means that the power brick died, so there is no use to fix for what I know.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 12
总计 4,408
