跳转到主内容
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
1209 个问题 查看全部
Engine spits oil from the spark plug hole
This MasterCraft 3-in-1 mower with Tecumseh LEV120 engine was standing for multiple years in a garage when we bought the place. I cranked it and it appeared not to be seized. I cleaned it up, repaired some issues around the wheels and added oil and gas.
When I tried to start it (primer bulb worked) I felt high resistance in the starter cable (pull start), to the point that I could have broken the string (I didn't). So, I took the starter assy. off and tried to turn the flywheel by hand (after unplugging the spark plug). It turned slowly up to the point of compression and then it turned really hard. Now I took the spark plug off and saw that it was soaked in (black) oil. I turned once more and found oil being spit out of the spark plug hole. Obviously the cylinder is broken in some way.
However, in order to determine if I should spend time on a repair attempt I need to know what kind of damage is might be and what it would take to make this mower work some more, this time for us.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can get a brand-new equivalent lawn mower from Home Depot for $250 right now.
Unless you know how to tear down and rebuild an engine yourself, I would get a new mower rather than fix this one. Sounds like it has serious engine problems.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Klaus Schmidt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 41
总计 2,704
