跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
How to completely discharge iPhone if it randomly turns off?
I have a problem with my battery - the phone randomly turns off. As far as I understand I can try to calibrate it - I have to charge it on 100% and leave on one-two more hours. And then to discharge it until it shuts down. But the problem is that it turns off randomly and doesn't discharge completely.
Is there a way I can do it? My only idea is to remove battery and connect it, for example, to a small bulb, so that the light will be on until the battery will discharge. Will it work or there will be the same problem because of bad calibration?
P.S.
Can't buy a new battery right now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hello Andy,
Sadly, you cannot just connect your battery to a bulb to fully discharge it then charge it again and hope it works again. Firstly, because iPhones uses different connections to connect to the phones motherboard compared to normal batteries like AA or AAA, you cannot connect the battery to a lightbulb. Secondly, because batteries run on indedendent cycles of collection of electrons and releasing them to charge the phone (extra sciencey stuff), the battery cannot "recognize" a full charge. Your phone does that in its software. Throughout the phones lifetime, when you charge it, the battery loses some of its ability to hold a full charge and proceeds to get weaker and weaker. But either way, the battery will just need replacing. Because you are on an iPhone 4, the battery is really old and thay is why you are most likely having issues. Since the phone is so old, it may only he holding less than or equal to an 80% charge of its original capacity. So, unless you can get a new battery, you may need to upgrade your phone, or live with the issue.
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andy Black 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
