跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Battery burst into flames after removal!
The attached photos, ( if you can see them) show the destructive power stored in an iPhone 6 battery with approx 70% charge on it. After removing it from the phone, I was straightening it back out, when suddenly it started to flare up ! I had to throw it, it bounced off a door and onto the floor where it continued to burn intensely like a signal flare for what seamed like a 10 seconds or so. This would have destroyed the phone had it gone off while removing it, or seriously burnt my hand for sure in a split second ! Set off the smoke detector, filled the shop with soot and fumes, smelt like a welding shop after, just want to say be very careful with these, I have probably swapped out 100 or more batteries over the last 4 years and never had one go off , now I have a metal can full of water right beside me when doing any iPhone battery swap.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Over stressing the battery in the removal process often leads to a failed battery (one of the reasons glued batteries is such a bad idea). Most of the time it just takes a small puncture to set things off.
You’re lucky! It could have been worse!
这个答案有帮助吗?
得分 2
添加一条评论
Did you use metal prying tools or any sharp tools to remove the battery? This should never be done. It's better to use plastic playing cards / flexible cards and some ethanol / isopropyl alcohol instead.
Also don't bend the batteries or pry at them too much it'll puncture the battery.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Steve Adams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 107
