跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Phone dropped in water, won't turn on.
I was at my pool with my cousin as a joke he pushed me into the pool. I had a bathing suit on so I wasnt worried until i realized my phone was in my pocket. It was in the pool for at least 5 minutes. I also have a hole at the top of the phone that exposes the inside.
What should I do? I have many important photos on the phone that it would be bad to lose.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Take is straight to a reputable repair shop that can open it, clear out the remaining liquid and prevent further damage.
The longer it stays in there, the more damage it will create. Rice will do nothing. Faster it is opened and properly cared for, the better chance you have!
这个答案有帮助吗?
得分 2
添加一条评论
I had this problem too, but not of the pool but mine into the sink.. Well, you should get your phone out of water immediately after it dropped down there. Don’t attempt to open or do anything to it. Open the back base of your phone, then use a soft towel to dry some wet spaces. Then close the back base again. Now, put it somewhere with the sun shining, not too sunshine, then leave it for 3-5 days. ( Make sure no one disturbs it ). Then now try opening it, if it doesn’t still work, well you have to go to the repair center to save your phone. Hope this helped.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liam Flan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 408
