跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone loops apple logo after battery replacement
hello i just bought a replacement battery because my old battery didnt last at all. so i bought your kit for it and watched a video on how to install it and i got it installed perfectly an everything worked, i put it back together and it turned on. it was at %50 and it eventualy died then when i went to charge it , all i got was the apple logo staying on for about 5 seconds. so i tried putting it into recovery mode but as soon as i unpluged it from the wall 3 seconds later the screen went black. so i retried and retried , im not seing a low power icon its just the apple logo repeting and repeating. so i opened it up again and reset the battery plug, and still kept repeating. i tried following this tutorial here ----Flashing white screen after battery replacement
but to no avail. they said it was a seating issue . which in my case it wasnt because it was working fine before it died, they also said if that didnt work it was a faulty battery
any help would be greatly appreciated thx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It sounds like a faulty battery to me. You should contact iFixit directly (not the answer forum) and tell them to send you another.
这个答案有帮助吗?
得分 1
4条评论:
would i have to pay for another one?
完成的
and also how do i contact them.......thanks troy
完成的
ONE MORE THING and the battery was working so i dont understand why would it be faulty if it was in fact working
完成的
I don't know if you would have to pay for another one. I would assume not since the one they sent you didn't work, where the old battery did boot up. Here is a page I found where you can contact iFixit to see about a warranty swap: https://help.ifixit.com/category/133-con...
The new battery never worked right, only the old one. I think they sent you a bad new battery.
完成的
添加一条评论
Sounds like either a bad battery, or damage from the disassembly. Hopefully just a bad battery! Quickest way to test is to install the old battery and see how it responds. If it boots up fine, bad battery, if it reacts the same, it is either the new faulty battery or board damage.
这个答案有帮助吗?
得分 0
1条评论:
funny thing is that i acidently destroyed the battery sooooooo
完成的
添加一条评论
添加你的答案
MfreakTV “MfreakTV” 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 76
