跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
shorts alone pp gpu line
Quick question I have a 6s plus I'm trying to work out if I have a short on pp gpu line as all the caps on that line are testing shorted and area is extremely hot I have been told a lot that most meters will beep on that line because it's low residents to ground but what I don't understand is that pp cpu is nelly the same but won't sound or sound on anything at all which makes me think it's a short and my next step would be to remove L 2010 L2011 L2012 L2013 to isolate to see what end its coming from please give me some pointers thank u
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
What is the actual reading (in Ohms) for that line? That will tell you if you have a short or not.
PP_GPU on the 6S series is typically quite low, around 6-15 Ohms. PP_CPU is a bit higher but generally the 6S series have lower resistance than the 6 series of devices.
A true short would be less than 1 Ohm. If you truly suspect a short, then removing the coils will help you understand on which side of the circuit it's coming from but keep in mind that removing those coils is pretty destructive so make sure you have replacement coils on hand.
这个答案有帮助吗?
得分 4
2条评论:
Hi my reading is 0.006 in diode mode ????? Confused
完成的
Measure it in resistance mode.
完成的
添加一条评论
iPhone have serious issues like that i search and do many things but find shorting cpu is the main causes of that.Beside them there is also the fault of faulty capacitor near cpu.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for everyone's help I am waiting for my new screens to come and I will let u now my results if anyone still has a similar issues please comment you fix thank you
完成的
添加一条评论
添加你的答案
dylanrichter44 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 1,707
