跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 个问题 查看全部
Ice maker not working
Ice maker quit making ice. I have changed the water filter and not getting any water still. Does it take a while to begin working after changing the filter?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Check your solenoid or float and ball assembly, however yours is equipped. If solenoid equipped, is it getting voltage? Is it a type that may be cleaned and checked by you? If float and ball, check and clean.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Karen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 343
