跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Short on caps near pmic
Hi again I'm really stuck with this one I have replaced Tigris Ic mosfet ic tristar ic I'm unsure if it's fixed the shutdown issue yet but in addition to that I have released its going through power like nothing one hour YouTube video used about 30% so I looked at big pmic and found caps c2016 c2013 c2017 c2020 c2014 c2015 c2019 and c2021 all to be shorted can anyone help with this issue as I'm sick all I can think of it replace the pmic and no sines of water damage or corrosion gave it a ultrasonic bath
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Those caps are on the PP_GPU line and it is a very low resistance line, typically in the 10-20 Ohm range. Most meters will "beep" when set to continuity mode with that kind of resistance. So unless you are measuring <1 Ohm, I would say the readings are normal.
You don't really say what the original issue/problem was so I will just say that if you have fast battery drain, try a known-good battery first and then remove all peripherals and test them individually. If the drain occurs even with just the logic board (with a known-good battery and Lightning port), then you need to measure all of the PMIC & BB PMU lines.
这个答案有帮助吗?
得分 1
1条评论:
So it's actually all the caps on that line my error I was wondering if 1 cap was burned out and acting as a wire to ground can this do that and the original issue was that it would kill new battery's as in new battery will only last a month before it's completely dead and not even a good phone can charge will die at about 50% and by the end of that day the battery is so drained it will boot loop but comes good with a good battery works fine for another month I have found that c2018 is a lot hotter than the rest and has a darker colour with a mark on pmic around it
完成的
添加一条评论
添加你的答案
dylanrichter44 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 392
