跳转到主内容
Sony Xperia Z4 (known as Sony Xperia Z3+ in Europe). Smartphone with 5.20-inch 1080x1920 display powered by 1.5GHz processor alongside 3GB RAM and 20.7-megapixel rear camera. It was released in 2014.
20 个问题 查看全部
Not charging after replacing battery
Hi, i just received a new battery for my Xperia Z3+ Dual (LIS1579ERPC).
I replaced it and it's not charging anymore. Conector seems to work because it makes the sound when connected and PC recognizes it but battery icon does not change to charging status and under batter menu it says "not charging".
Tried with USB and original charger. Both with the same result.
New battery is on 20% charge. I didn't do what the note inside the package says to drain it to 10% and charge it to 100% uninterrupted because of the problem explained above.
I tried putting back the old battery and it's charging OK. I don't have another phone to try the new battery.
What can i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It's a faulty battery. Try contacting the supplier / seller you got it from for a replacement.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, i bought it from iFixit and used a forwarder so sending it back for a replacement is not an option.
完成的
添加一条评论
添加你的答案
Andres Maidana 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 219
