跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
498 个问题 查看全部
Washer doesn't drain after first cycle, it fills again
Kenmore 110 washer.
Have just replaced the water pressure control switch but that didn't fix issue.
Water fills to level and begins agitation. Washer DOES NOT DRAIN before rinse cycle, instead just fills a second time and causes the washer to overflow.
If i manually set it to spin, it does spin and drain, so I know that works... just can't figure out why it doesn't do it on its own.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @kg531 ,
What is the full model number of the washing machine?
Does the timer switch move through the cycle to the rinse position?
完成的
Hi @jayeff The model # is 11 20712 991
I've tried swapping out the pressure level switch and I also replaced the lid switch but it still rushes through agitation and fills again without draining.
I now have a replacement timer on order- It does cycle through the stages but the timing is off. Was hoping it wasnt this because its the most expensive part to replace, but also hoping it IS this, because if not, I'll be out of ideas.
完成的
添加一条评论
1个答案
最有帮助的答案
If your Kenmore 110 Series Washing Machine is not draining after a wash cycle, see the Kenmore 110 Series Washing Machine Won’t Drain problem page for possible causes and solutions.
Cause 1
Water Inlet Valve
Try shutting off power to the washer while the machine is filling with water. If the washer continues to fill with water even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Cause 2
Pressure Switch
The pressure switch shuts off power to the water inlet valve when the proper water level is reached. If the pressure switch fails, the water inlet valve will continue to fill the washer tub with water, causing the washer to overflow. Before replacing the pressure switch, check the air tube to the pressure switch to ensure that it is clear of debris and is not leaking.
Cause 3
Low Water Pressure from House Supply
The water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the water inlet valve does not get enough pressure, the valve may not close fully after the power is shut off. As a result, water can leak into the washer and cause it to overflow. Check the water pressure to determine if it is sufficient.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for your suggestions. I have tried unplugging power to the washer while it is filling and it does not continue to fill. Water inlet valve appears to be OK.
I have also replaced the pressure switch but still experience the same behavior.
I then replaced the lid switch too, but unfortunately that was not it. Water pressure is fine as well- the machine fills up quickly and does shut off after the first fill.
完成的
Been having some washing machine issues myself lately. Just curious, did the timer fix your problem?
完成的
添加一条评论
添加你的答案
KGusername 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 2,060
