跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Replaced battery now bottom of the screen acts unresponsive
Hi all,
Yesterday i replaced a iPhone SE battery. Everything went well but after putting everything back in the screen works, except for a small piece of the bottom. Its right at the place where the spacebar is located etc. The screen is original.
I've took everything out en back in like 10 times but it still wont work. Rest of the screen is working perfectly. What could be the problem did i damaged some kind of flex cable? must say the battery fitted really tight between the frame en logic board, could that be the problem, cause i cant remember if the original battery fitted that tight as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I think it is a hardware issue on the motherboard.
完成的
添加一条评论
1个答案
You might have to replace the lcd again ... screen has dead pixels
这个答案有帮助吗?
得分 0
2条评论:
Replaced the screen, didn’t work. Could it be the battery?
完成的
that battery not suppose to cause that problem because the device is coming like normal
完成的
添加一条评论
添加你的答案
Pascal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 83
