跳转到主内容
The Honda CR-V is a compact crossover manufactured by Honda since 1995. Since It uses the Honda Civic platform in an SUV body it was called "CR-V" which stands for Comfortable Runabout Vehicle.
130 个问题 查看全部
Can A mechanic cause any damage when replacing a serpentine belt
My power belt broke on my car. I took it to a mechanic called pepboys and they replaced the belt. My car broke down that same day. My car was overheating and the heat level was going on up after I put coolant in my car. I never had problems with my car overheating before. I was wondering could they have down something when replacing my car.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
What caused the belt to break in the first place . Serpentine belt dont tend to break without help. You mentioned adding coolant , was the car heating up before the belt broke or not until after . Check the water pump pulley also check the idlers to make sure there's no bad bearings . The mechanic didn't likely cause the problem but he didn't see the one that was staring him in the face. Hope this helps
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
Sounds like your water pump is failing or seized. A competent mechanic should have been able to diagnose this situation when replacing the serpentine belt.
这个答案有帮助吗?
得分 4
1条评论:
A GOOD or BAD mechanic should have done a thorough inspection to try to UPSELL extra work to you. Was it your power steering belt that broke, did they try to sell you all the other belts or is this a single serpentine belt? A good mechanic would have inspected all pulleys and bearings for an upsale opportunity.
If you have multiple belts, let's assume 3, which belt was for power steering, the first or second or third. Example if it was the second in my shop, I would replace the first for labor free if you buy the belt, I know not everybody can afford the right job but if I have to remove something to change a broken part, why charge more labor to replace an item that needs replaced if its part of another related job.
完成的
添加一条评论
添加你的答案
wzakia96 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 89
总计 1,606
