跳转到主内容
The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
How to remotley disable FRP lock?
I have recently flashed a custom recovery on this phone. Since I forgot to disable frp lock (Re-enabled it by setting up phone after flash) it will be blocked from entering the recovery mode. for some reason it will boot-loop non stop. It will try to load the recovery then crash reboot and repeat. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You need to put the phone back into download mode via holding volume down + power + home constantly and reflash the firmware or stock recovery file onto the phone.
How to flash firmware if you need it, flash with home_csc and not the non-home csc to avoid factory resetting the phone if needed:
http://updato.com/how-to/how-to-install-...
When you get phone working again go to settings, about phone, software info tap build number 7 times then go developer option and enable OEM unlock.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Ethan Leroux 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 4,904
