跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Phone won't turn on after repair
I recently replaced the LCD and the digitizer in my 3G. After replacing I got a blank white screen. I've looked thru all the Q&A and I've tried to do some of the things others have done and now I'm not able to turn the phone on at all. Please help!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
8条评论
Why did you replace both the LCD and digitizer? Does iTunes recognize the iPhone? Does the mute/vibrate switch make the iPhone vibrate now? Try a hard reset, at same time hold down both Top/Power button and Home button for about 15-20 seconds if it works iPhone will come on.
完成的
Front screen was cracked and there were a few pixels that were out so did both at same time. I haven't tried hookin up to iTunes yet but the vibrate switch isn't working now. I've also tried a reset even tried using the old LCD in the phone again and has same problem. I'm running out of things to try just looking for a fresh mind!
完成的
Well it is important to see if iTunes will recognize the iPhone. Did you remove the frame from the LCDs or did the new LCD already have a frame attached to it?
完成的
Ok after it set for awhile the vibrate function started working again I also checked it with iTunes and it does recognize the phone. The LCD I received already had a frame attached to it.
完成的
Ok I've checked the connections again and they are fine but now I'm not even getting a back light. I guess it's the logic board which really stinks!
完成的
显示更多的3条评论
添加一条评论
1个答案
已选择的解决方案
Either your LCD is bad, not connected correctly (connector 1 to Logic Board) or your Logic Board connector or LCD controller is bad. Carefully open iPhone (I would do it OFF, but since it is 3g, might be OK, not sure), carefully reseat Flex Cable #1 (LCD flex). See if this fixes it. If not you may need to try another LCD. If it is damaged Logic Board, ouch. But even Logic Board can be repaired. Good luck. Brad
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
steefan60 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,382
