跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Killing batterys unexpected shutdown at around 50%
Hi I have a iPhone 6s plus that I have had to replace battery around 8 times as the battery works fine for around a month then dies at 50% like its flat pug it in I get 50% than continues till the battery is completely drained replace battery then like new for another month it's be like this since it was stolen from me and I got it back smashed now I'm about to replace the U2 Ic but I want to no if anyone knows of any other chips that can cause this so I can repair
Update (06/29/2018)
Hi again I'm really stuck with this one I have replaced Tigris Ic mosfet ic tristar ic I'm unsure if it's fixed the shutdown issue yet but in addition to that I have released its going through power like nothing one hour YouTube video used about 30% so I looked at big pmic and found caps c2016 c2013 c2017 c2020 c2014 c2015 c2019 and c2021 all to be shorted can anyone help with this issue as I'm sick all I can think of it replace the pmic and no sines of water damage or corrosion gave it a ultrasonic bath
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
In addition to replacing the U2 IC, I would recommend inspecting the board under a microscope to look for corrosion or deposits (as a result of water damage) that could be shorting out connections, this would lead to excess battery drain. If there is corrosion/deposits from water damage, the first thing I would recommend is a good cleaning.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dylanrichter44 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 115
