跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
New Battery Pack doesn't charge
Hello
I replace the Battery as described. I Icon show the Battery will be chardged but it sucks on 1%
Any Idea what went wrong?
Regards
Gérard
Update (06/25/2018)
The part most right of the connector is missing
The spudger of ifixit isn't the correct tool. The fingernail is a better tool!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hello
The situations is more strange as thought. The iPhone was charged now for more as a night and it displayed it was only charged with 1%
I left the iPhone on my desk and took my old iPhone 4S for my work. At night when I came home the iPhone SE was still on 1% without be on the charging cable. So it looks like the battery isn't communicate with the phone. All Mails during the days are loaded. The iPhone SE is visible in the Network by the DHCP Server and in iTunes (Version 12.6.2.20) I can still make a backup of it ?!?
Could it be an issue with a bad Battery Back. The Original Battery has Part 616-00107 the new one has 616-00106!
Regards
Gérard
完成的
添加一条评论
2个答案
tristar ic, it fails when you use cables that arent original or MFI certified.
这个答案有帮助吗?
得分 0
4条评论:
Very strange! Before the Battery Swap this cable works fine. This cable is able to charge my iPad Air 2 normally!
I charging always on the Computer. I will search for the Original USB Charger and give it another try.
Normally my iPhone SE is in an Original Mophie Juice Pack Plus. Even with the Pack (green switch) or with the Charge Cable of the Pack it won't load more as 1% (the Juice Pack is blinking so this seems to charge)
I will try to buy a new Cable in the local Apple Store but I can't image this will solve the problem
完成的
in that case, look next to battery connecter. There is a few very small components (caps and filters). one is for battery gas gauge and can be easily knocked off during a battery replacement.
完成的
hello lukerockhill
I will make a picture. propably you are right. their should be 4 components I see only 3. They are soo small. I used the original ifixit manual and the spudger of the ifixit toolbox. (Step. 12). It should be better to use the fingernails for this purpuse :-(
Is there I way to fix it? Bridge it? What component is missing?
完成的
dont bridge it, a capacitor goes there so you would be shorting out the line if you just connected the two pads. in the picture i think i see the cap that fell off touching the other component to the left of where it was. try to remove it and see if it works. alot of times caps are there just to smooth out the power and will work still when one is removed. but the component it seems to be touching is a filter for battery gas gauge.
完成的
添加一条评论
Try to charge the battery with the phone off.
这个答案有帮助吗?
得分 0
1条评论:
I tried this also without success!
完成的
添加一条评论
添加你的答案
Gerard Dirks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 33
总计 278
