跳转到主内容
The Lenovo 100s chromebook-11IBY is an 11.6'' laptop featuring a 1366 x 768 display with up to 8 hours of battery life.
5 个问题 查看全部
Lenovo ideapad y700 15inch display problem
my Lenovo ideapad Y700 15inch display isn't working. What happened just the battery was low and didn't realize until the laptop turned off I plugged it turned on but no display showed not even backlight! I connected it to an external screen it's perfectly running tried everything its not working! Any help is appreciated thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is a common problem with Lenovo the display cable gets pinched off in the hinge . replacing the cable will probably fix the issue. But before you go to the trouble of replacing it you may want to try this . Pull the battery unplug the laptop and then hold down the power for about 60 seconds . If you cant remove the battery you can also do this by replacing the ram and reinstalling These guides will help
Lenovo 100s Chromebook-11IBY
这个答案有帮助吗?
得分 3
6条评论:
Hello, thanks for your reply, i tried removig the battery and the ram it didnt work maybe its as you said the wire. However iam afraid its the nvidia vga burnt? Could it be the case? (NB: I am using it normally using an external display)
完成的
Knowing that the laptop have 2 vga s the intel and nvidia
完成的
are there actually 2 vga ports on the laptop?
完成的
If the vga ports work and you can connect to an external monitor and get a picture then the graphics card is ok and the problem lies in the cable or the screen itself . It could also be in the invertor if its so equipped . replace the cable first as its probably the cheapest part
完成的
how does one replace the cable? is there a tutorial? if not, where can i just buy the cable (so i can give it to someone who is better at hardware than I am)?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Ali Charara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,954
