My HP DV7 does not want to switch on after I applied Colgate on the pr
I applied Colgate on my CPU while I was cleaning my motherboard with spirit.
Now the laptop doesn't want to switch on after the Colgate saga. Is the process reversible?
Sounds like the damage has been done. However, now that the damage has been done, it wouldn't hurt to clean the CPU (and the heat sink) and see if that fixes the problem.
Get some Arctic Silver ArctiClean to clean the CPU and heat sink:
Then get some Arctic Silver 5 thermal paste and use it to affix your heat sink to the CPU:
[关联产品丢失或禁用: IF179-010]
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 342
So you used toothpaste instead of thermal paste? Why did you do that!
由 DanJ 完成的
@danj probably because of a parody tutorial that didn't make it clear that it was a joke. :/
由 Rachel Acosta 完成的
Rachel - You never know ;-}
People do the strangest things!
由 DanJ 完成的
Hi @adotdolla
Oh dear.... colgate is no go........ get arctic silver thermal paste, etc....
so what is happening now? have power and no screen?
suggest you to clean up those colgate toothpaste and use proper thermal paste....
clean up and see how.
hopefully it does not short or damage your laptop.
由 Augustine 完成的
