跳转到主内容
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
129 个问题 查看全部
I forgot my screen lock pattern and would like to know how to reset it
I replaced the screen on my voyager ii and havent used it in months. Thought maybe i could access it from my android phone but it cant find it. Ho can i reset the lock pattern
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
I FORGOT MY P[ROSCAN PLT7777G-Q PATTERN, PLEASE HELP ME. G.Cyrus
完成的
添加一条评论
5个答案
已选择的解决方案
#1 Make sure tablet is powered off.
#2 Hold down Volume + button and Power button at same time.
  1. 3 When screen comes on let go of Power button.
  2. 4 When the large Android shows on screen let go of Volume + button.
  3. 5 Use Volume – button to scroll to Wipe Data/ Factory Reset
  4. 6 Tap Power button to select.
  5. 7 Use Volume – button to scroll to Yes.
  6. 8 Tap Power button to select.
  7. 9 Tap Power button to select Reboot System Now.
这个答案有帮助吗?
得分 10
9条评论:
Thanks Justin. Just an issue now with a laggy touchscreen. But i'm in. Thx again
完成的
i for got my password a week ago and this really helped me thx
完成的
Thanks by little cousin is able to play now my cousin the little cousins mom got from a friend who forgot the pattern lock in 12 am my big cousin is happy thx again
完成的
Thanks Justin, you are awesome! Now I can swap this tablet for my phone with my grandson! Yayyy!
完成的
Oh my goodness... THANK YOU!!!!
完成的
显示更多的4条评论
添加一条评论
this solution will reset your device. Which is the only way to unlock it
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the reply. Worked like a charm
完成的
添加一条评论
I still can't get the pattern lock off I've factory data reset the %#*@ thing and re booted t he system and its still locked does anyone have any suggestions please help
这个答案有帮助吗?
得分 1
4条评论:
I am having the same issue. Factory reset multiple times and still asks for the pattern to access the tablet. How do we get passed this?
完成的
I am having the same problem. Please help!! Why want the pattern change??
完成的
I am having the same issue. I have reset it multiple times and its still locked. Please help
完成的
Same here. No one seems to know what they're talking about.
完成的
添加一条评论
Hi the only way to get past the lock screen is to reset the device back to factory in the recovery menu of the device. You should try to power it off then hold the down button and power button this should take you into recovery. From there you should scroll with the volume buttons and wipe/ factory data reset the device then reboot.
这个答案有帮助吗?
得分 0
添加一条评论
thanx……You made me feel like I knew what I was doing….
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dale Reese 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 94
过去 30 天: 384
总计 14,220
