What can be the cause of these intermittent screen displaying glitch?
Hi,
My MacBook Pro have intermittent screen displaying glitches, as you can see on this video I just took.
SYMPTOMS VIDEO:
http://site-web-reims.com/collab/MbProLa...
REPLACED PRODUCT :
I have already replaced the LVDS data cable :
MacBook Pro 15" Unibody LVDS Display Cable
GUIDE :
I have followed this DIY guide successfully :
MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement
After the replacement, the glitches are still there :-/
What could be the cause of such an intermittent glitch symptom ?
Thank you very much ;)
Alexander
7条评论
Have you checked to see if it still happens if you connect it to an external monitor?
由 Rus Weeks 完成的
Sorry for this missing information.
Yes : the display is correct on an external monitor. I suspect that the LCD display have internal lesion ?
由 Alex Laforge 完成的
This will sound daft, but, try pressing different areas of the screen. I've had thing like this in the past, for some reason this fixed the problem
由 Rus Weeks 完成的
Rus, I have pressed different areas of the screen, as you suggested me. It infortunately did not change anything : not worse, not better..
由 Alex Laforge 完成的
Try pressing around the edges where the bars are. You may need to take the cover glass off to effect anything here.
由 Dan 完成的
显示更多的2条评论
