跳转到主内容
加入维修社区 - 创建账户
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
Rear facing camera failure
Good day boys and girls. I have had an ipad 4 come in with a non-working rear facing camera. I have tried quite a few things, which I will list, with no success or change. Please note that the front facing camera works perfectly, as does the headphone jack. I am looking for some tips as to where to look next for the root of this fault.
Here are the things I have tried:
1. Hard reset (power + home): no change
2. Reset to factory defaults using DFU mode: no change
3. Replace rear facing camera woth known good unit: no change
4. Replace upper io board with headphone jack, FF camera and microphone: still no change
I have inspected the zif connectors for this upper io board under my microscope and they look pristine. No evidence of drop damage or water damage. Also no evidence of any previous repair attempts.
Any help with this would be absolutely smashing.
Thanks guys
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check to see if you have continuity on the PP2V8_CAM line and try to probe that line to see if voltage appears when the known good camera is plugged in and "turned on" (via the app).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Su99s 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 101
