跳转到主内容
加入维修社区 - 创建账户
1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
MBA won't turn on. No charge light on Magsafe charger
My daughter came home from school where her Macbook Air had been working fine. Not sure if it ran out of charge or she powered off. Have plugged it into the charger and there's nothing going on. Can't turn on the laptop. The charge light doesn't come on to the magsafe adapter charger. Have tried another charger that works and still nothing.
It had the logic board replace by Apple about 18 months ago, so I presume that's OK but couldn't say for certain.
Anything else I could try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @robjacko
No harm trying SMC Reset first
https://discussions.apple.com/docs/DOC-3...
完成的
The charger was fine. Used it on my MBP and it worked OK.
Last night, after leaving for a couple of hours, unplugged, my daughter pressed the power button and it came back on! The screen had some dark areas on the lower left...looked like dark spotlights. But they disappeared after a couple of minutes.
So no idea what happened, but all appears OK for the moment. Does make me slightly worried that something is on the way out big time...I'll see how it goes.
完成的
Dark splotches signal me the display what crushed by a book or something in her backpack.
完成的
添加一条评论
1个答案
最有帮助的答案
You may need a new charger. Try cleaning the MagSafe connectors following this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 141
