跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
Location Of Temp Sensors?
Hello, can anybody tell me where the temp sensors are located on an iPod Touch 5?
My device is giving me an over temp warning every 16 seconds despite remaining cool?
The flash function is also greying out after the first alert?
Locations of the temp sensors would be useful as I can then track down the suspected faulty component on the logic board.
I can't seem to find a schematic for this devices logic board anywhere?
Cheers for any help :-)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Unfortunately, there is no board view of the iPod Touch 5 but there is a schematic available on ZXW. There are four NTC Thermistors (10K Ohms) on the logic board. One is close to the battery connector, one in the "forehead" area, one near the CPU and one near the rear camera. They are small 0201 form factor and indistinguishable from resistors so they will be very difficult to find.
这个答案有帮助吗?
得分 2
3条评论:
Thanks. That's very helpful. Just to clarify...What area is the 'Forehead' area? Also , should I be looking for a burnt/ shorted component as an obvious indicator? Cheers.
完成的
The forehead is the upper front area of the screen (front camera & sensors). You probably wouldn't be able to differentiate a good from bad thermistor and the problem could be at the trace level or even with the PMIC (which receives the signal).
完成的
Thanks, will have a crack at finding the fault. Cheers for your help.
完成的
添加一条评论
添加你的答案
Paul G 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 8
总计 155
