跳转到主内容
The Sansa e200 series is a portable media player developed and sold by SanDisk, a brand of Western Digital for flash memory products including memory cards and readers, USB flash drives, and solid-state drives.
2 个问题 查看全部
Formatting erased firmware on my Sansa e250
I have a Sansa e250 with firmware v1 and I accidentally formatted the drive with the system files on it so now my PC doesn't even recognize it. When it powers on the screen is black with no back-light but the wheel light is on. Is there a way to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Andrew
some helpful links:
http://forums.sandisk.com/t5/Sansa-e200-...
In Summary
Downloaded the firmware first.
1) Double click on My Computer so that you can see it on your screen.
2) Turn the player off.
3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange.
4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button.
5) Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish.
6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7) Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Firmware:
http://forums.sandisk.com/t5/User-guides...
这个答案有帮助吗?
得分 2
7条评论:
There is nothing executable in the files I downloaded. i also tried to get my pc to recognize my player by the instructions given but didn't work. thanks for the quick reply though.
完成的
Hi Andrew, just trying as much as possible as seems Sandisk has removed some of the installer away from the websites.
Had you tried using Sansa Firmware Updater to recover your media device?
完成的
The updater did not recognize my player. I have tried installing the recovery tool but I have a 64 bit version of windows 10 and the product is designed for 32 bit windows xp.
完成的
I tried this also and it did not work. There has to be a way to recover a bricked sansa e250. Any other suggestions would be appreciated.
完成的
When I go to device manager Tango Digital Media Platform shows up and when I right click it it asks me to update the driver. When I use find it from Microsoft it says that I have to contact the manufacturer. I contacted SanDisk Global support and since this is a legacy mp3 player they do not have the driver for it. If anyone out there has the driver for it, I would appreciate if you would share it with me. If I had the driver, I think I can fix my unit. Thanks in advance.
完成的
显示更多的2条评论
添加一条评论
Tried rockbox?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andrew pauly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 37
总计 2,285
