跳转到主内容
加入维修社区 - 创建账户
MacBook won't boot or charge with and without battery
Hi,
here's what I tried so far:
- a different charger
- removing the battery
- cleaning the ports with alcohol
Sometimes when I connect the charger, the plug LED turns green for a second and then goes off. When I tried to power it on without the battery, it sounded like the fan started to rotate for a second and then stopped.
Do you think the MagSafe board could be damaged?
Thanks in advance.
EDIT: I somehow managed to get the plug LED turn green when I connect the charger. However, it won't turn orange. The MacBook still won't boot. When I press the power button, the LED goes out for a second or so and then turns green again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you still have some life in the system lets install this gem of an app: CoconutBattery take a snapshot of the main window with the MAgSafe charger connected and post it here for us to see.
If your system is not able to boot up as the battery is fully discharged then you’ll need a fresh battery. Its possible given the age of your system the battery needs replacing any ways.
这个答案有帮助吗?
得分 1
6条评论:
Thanks for your reply. Do you really think the problem could be cause by a faulty battery, even though the MacBook won't boot without the battery, either?
完成的
The process here was diagnostic not pointing to the battery as the root issue. But given the age of your system it likely needs replacing any ways. If you still have enough battery left to get the data now then thats fine.
The other direction which is more complex is to test the circuit using a DVM to test the circuitry out
完成的
Again, thanks for your reply. I decided to order both, a new battery and a new MagSafe board (since it's relatively cheap).
完成的
With your update note, your logic board charging logic will need repairs are you up to micro soldering & reading schematics?
完成的
No, I'm not. Why do you think the logic will need repairs?
完成的
显示更多的1条评论
添加一条评论
The problem is with your logic board, it can be the problem with Power Management IC.
Try with a different charger at first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wonthelm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 179
