跳转到主内容
Sony's 9.2 megapixel HDR-CX675 released in December 2015.The handycam captures 1080p HD recorder.
Horizonal lines on LCD and Tape header noise TRV118
Having an issue with a Sony Handycam Digital 8 that I picked up from a thirft store the other day.
Model: CCD-TRV118
The problem is intermittant....
- The LCD screen will show horizonal lines, usually when I touch or tap the area where the tape is located. This can happen when the tape door is closed, but the problem presents itself better when I try to tap it when the tape door is open.
- Sometimes the LCD screen will stop showing the lines, but sometimes, I have to turn the whole unit off and on again.
- When the LCD sceeen is showing these lines, you can hear the tape deck whirring, like the headers are trying.
I was thinking the camera 'thinks' it has a tape, when it does... maybe something is loose or dirty... However, why would the LCS sceen show pure horizinal multi-colored lines at the exact same time?
Any help would be appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
IRRC there are 2 ribbon cables that run between the main camera body and the display. One of these cables either has a crack or is loose in its connector inside the camera body. This should be fixable by re-seating the cable or replacing it.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sean gee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 365
