跳转到主内容
My screen is flickering lines while not moving mouse or pressing a key
Hello, I have a macbook retina late 2013 and today when I was turning it on, I had a little difficulty because it was not turning on, but after a few tries I accomplished to make it function.
The problem now is that the screen is flickering just like the image, but the intriguing fact is that it only flickers when I'm not moving the mouse/trackpad or typing, when I move the trackpad it stops completely.
Has anyone any idea of what could be causing this?
Thanks in advance
EDIT1: Discovered that is not the mouse to keep from flicker, if there is any animation, the screen will not flicker.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What happens when you plug in an external monitor? Does the image on it look OK?
完成的
it stopped after I reseted the SMC, but I could not test on the monitor
完成的
添加一条评论
1个答案
最有帮助的答案
I had one with this issue a while back, a 13" 2015 model. IIRC, it would only show the diagonal stripes when in an OS, or intermittently (holding option key on boot would show picture fine I think). The issue was related to the logic board, I believe it was related in some way to the CPU integrated graphics. I didn't spend too much time on it though, since there was no physical or liquid damage present to suggest a cause, but it was definitely logic board related.
Not a very common issue, but seems to be a rare fault on these and have seen 1 or 2 A1278 models with the same problem. Try outputting video to an external screen to be sure and if you are still having the same issue, try a replacement logic board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
viccsouza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 1,580
