跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Can you replace the home button and still retain functionality?
Just looking to retain home button function, I am not concerned about retaining Touch ID.
If it can't this is going to push along of schools into paying for apple care.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Replacing the Home Button will not retain the TouchID functions but it will allow you to "push to click". If you want to change the HB yourself, check out this guide.
这个答案有帮助吗?
得分 5
2条评论:
That guide only tells you how to remove. I have found no documentation concerning home button function after replacment.
Just wanting to see if Apple pulled the same trick with the home button that they did with the iPhone 7 and 8.
完成的
It's a physical actuator, just like all the iPhones before the iPhone 7. You can see it in the picture above (that little black dot in the middle of the button). So if you change the button, you maintain "push-to-click". The iPhone 7 has a solid state button which is why replacing it kills all functionality.
完成的
添加一条评论
Nathan,
On the iPad 6 if you replace the home button it will continue to work as a home button without Touch ID. The issue regarding the iPhone 7/8 was due to it being a solid state button, while the iPad 6 button actually physically moves.
I hope this helps,
Charlie B.
Source: 2 Years experience
这个答案有帮助吗?
得分 2
1条评论:
Do you mean after screen replacement with original home button still Touch ID will not work ?
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan Selby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 4,596
