跳转到主内容
The Explorer saw significant exterior, interior, and suspension updates for the 1995 model year, losing all its exterior bodywork shared with the Ford Ranger.
Ran out of gas but it won't start
I ran out of gas and I've put plenty of gas into it, Checked- fuses, relays, vacuum hoses, injector's, fuel filter, pressure,spark plugs. I even dropped the gas tank emptied and cleaned it out.
rns over but will not start. The only time we do get it started is when we sparay starting fluid.
We have done everything I can think of as far as fuel goes. So what else would prevent it from starting?? Could it be the anti theft got activated somehow and preventing from starting?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
That might be air getting in the fuel line, you can try to get it out by starting the motor 10 times or so, that might work.
这个答案有帮助吗?
得分 0
2条评论:
It could also be that the fail/safe mode engaged, your best bet is to take it to a garage it think.
完成的
How do I disengage the fail safe mode if it's stuck on that?
完成的
添加一条评论
Have you checked the Fuel Pump?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RosealieReynolds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 306
