跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
TV defaults to Analog
I have an RCA TV, model number 27V414T. It is an analog and digital TV - it came out right before everything switched to digital.
The problem is, it defaults to analog; and the only way to switch between analog and digital is with the remote. But the remote is broken.
I programmed a generic remote, so I can operate the TV that way, but it won't switch between digital and analog.
Is there a way to get it to default to digital, or am I stuck buying another remote?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I found the answer. I go into the TVs menu, and I choose to scan the channels. Right before the scan is done, it asks me whether it is digital or analog, and antenna or cable. I select digital and antenna, then exit the menu. Problem solved!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
MrJimPhelps 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 43
总计 2,195
