跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Screen ribbon plug will not seat
The screen has 3 ribbons that need to plug into the phone. The first one snapped in fine. The second plug would not snap in. I tried snapping the original screen and it snapped in with no problem. I was not able to install the new screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Inspect the connector on the phone and on the screens. If the old one snaps in fine then it's possible that the connector on the screen is damaged.
这个答案有帮助吗?
得分 0
2条评论:
Or it could be that the OP is trying to plug in a 5s screen on a 5C which use different connectors.
The 5c screen has an extra screw hole at the top right that screws into the metal back plate that goes behind the screen.
完成的
You're right. I forgot about that. I usually compare the size of the black plastic part near the top of the phone. The 5s is thinner than the 5c
完成的
添加一条评论
添加你的答案
Douglas Feltkamp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 42
