Can I upgrade iMac (Late 2015) fusion drive to SSD?
Hello I was wondering if iMac (Retina 5K, 27-inch, Late 2015) was compatible to have the fusion drive upgraded to SSD? Specifically the Samsung 860 PRO 1TB 2.5 Inch SATA III Internal SSD. Will it fit and work? Do I have to take both drives out (both parts of the fusion drive) or can I leave one in? Apparently I need to buy an In-line Digital Thermal Sensor Cable and a 2.5" to 3.5" hard drive bracket as well? Or is there another SSD I can buy that won't require those?
1条评论
To clarify things you damaged the PCIe slot hardware. So you would need to find someone who could fix the logic board or replace it.
由 DanJ 完成的
