跳转到主内容
Toshiba Satellite C55-A5281 - 15.6" - Pentium 2020M - 6 GB RAM - 750 GB HDD - US
2 个问题 查看全部
White Power LED, no fans, screen, or other signs of life
Power LED only shows after pressing the power button with the battery in; not with the charger alone. No charge LED when plugged in. Have changed RAM and switched seats, unplugged and re-plugged all ports on the mobo. Any ideas? The laptop was received after someone attempted to replace the bad screen and it would not respond after. No signs of water damage.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try an External Monitor to check that at least the Laptop is POSTING. Try the VGA Port, if nothing shows up, try to switch the output to the external monitor using the keyboard key. Let’s just hope that the screen is dead no damage to the Internal Motherboard. :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pcm 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 138
