跳转到主内容
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
42 个问题 查看全部
Pump always on, lower pressure, water leaking
I have a Kärcher K 2.01
Recently, when turned on (= electricity switch on) but without pulling the trigger, it started to "kof", that is to turn its pump on and make the same noise as when you use it, but even when idle.
It did so in short bursts for a while.
Now, the pump is always on, even when you don't pull the trigger, there's a little less pressure (though still usable) and you can see quite a lot of water leaking out of the yellow box.
Is this repairable?
If yes, how?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Obtain a ‘Piston seal’ repair kit and renew the three seals. The water is leaking past the seals and causing a drop in pressure. While it’s apart renew the large ‘O’ ring body seal too.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Washington 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 193
