跳转到主内容
car turns on but when given gas dies. engine light on.
Recently got my car fixed by replacing the ignition switch. in the last couple of weeks i have also replaced spark plugs, wires, rotor cap and rotor along with the Fuel filter. it has been driving and idling pretty ruff and as of today driving it home i was giving it gas to where it felt like it had no power till i finally came to the point of my gas pedal all the way to the ground with the check engine light ON it didn't t wanting to go anywhere at this point. i was lucky enough the side road opened up to where i wasn't stuck in the middle of the road. i ended up getting it towed home . car starts up but wants to die.
91 civic wagon , Auto
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Have the timing checked . Its probably the timing belt has stretched or slipped . Honda timing belts should be replaced every 60,000 to 100,000 miles. depending on how you drive . Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
sandyperaza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 166
