How do I check for a short in my dishwasher
my dishwasher stopped I checked the junction box and the nuts were burned out I fix that, still no power to the unit, I changed the control board twice & the door assembly, I've got 120v at the junction box, also power to the door switch but once I connect it to the control board no power. So how to I check for a Short in the components. It's a Frigidaire FDB1050REM0
2条评论
why would the thermistor stop power to the board? I thought that affected the heat & drying . I've replaced everything the board the door switch & the circulation pump and I've got power until the connect the board and everything dies at the harness, this is crazy to me, any last advice it looks as if I need to be shopping for a new dishwasher
由 walter 完成的
I checked the Thermistor & High limit Thermostat and the Thermistor is bad so I will try that and let you know if that works. Thanks for your help with this problem I really appreciate it very much
由 walter 完成的
