跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Home button tap isnt working but touch ID is
I have two iPhone 7 plus's one Was working completely fine Until I decided to test out the screen on the broken one that Is waiting for parts. So the broken one needs a new screen and a battery I replaced the battery and figured well lets test it out with my phone that's currently working so I took of the screen and attached it to the other and everything turned on and worked except the home button the touch it and the ID witch I was expecting but when I put it back on the original phone only the touch ID works and not the home touch its self I have to use the assist and also now the volume will not go up or down with the buttons it registers me trying to turn it up and down but doesn't do anything. I tried a hard reset a factory reset and I am just all out of ideas !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I know its been awhile Wanted to thank everyone for the help the cable was damaged I replaced the screen and everything worked again .
完成的
添加一条评论
3个答案
已选择的解决方案
As for the volume buttons. Check that the cable is plugged in and not ripped cause it runs under the battery so it is possible that it was cut. They are very fragile and thing cables.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If the click function doesn't work but the Touch ID does, then that is caused by a damaged IC (Turtle IC / U10) on the home button flex. This typically happens when the flex is transferred from one screen to another. The IC is sitting on some tiny solder balls and when the flex is pried off the screen, those solder balls can crack or break.
This can be repaired but requires a micro-soldering repair.
这个答案有帮助吗?
得分 4
1条评论:
Yeah that's exactly what I did . I transferred the screen to another phone to see if it would turn on then when I put it back the button wouldn't work and the volume and the call speaker .
完成的
添加一条评论
Try to change the home button from other display and see if she’s working and try to make Rest of ur phone
这个答案有帮助吗?
得分 0
1条评论:
Hello I know this is an older post so I realize I might not get a response. I have this issue and I know the solder repair won’t work because I tried two other known working aftermarket home buttons and they won’t work with this phone either. I’m suspecting a software issue and if that’s is the problem I’m wondering if anyone would have any feedback on that
完成的
添加一条评论
添加你的答案
hughes 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 44
总计 8,592
