跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
RAM or SSD first?
Long story short, this mac is running the original 2GB of RAM and the stock hard drive. Should I upgrade to 8GB of RAM first or a SSD first?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
When you do the drive don’t forget your system is only a SATA II (3.0 Gb/s) system so make sure the drive you get is able to run at this speed.
Depending on the size of the drive you get it can get quite expensive. Given the age of your system I wouldn’t put too much into it won’t support macOS Mojave (10.14) so High Sierra is it for this puppy.
Frankly, if you are running El Capitan or newer you should max the memory out to the full 8 MB this system supports before doing the drive.
这个答案有帮助吗?
得分 2
添加一条评论
in this case personally i could do SSD first, its always a joy to have an SSD. yes your RAM is low, but SDD is in MY opinion a priority.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Derrick Kinsey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 321
